Morning ![]()
Well, as the title says, Iām designing and manufacturing a custom intake for my 1.0:
As you can see, it will consist of 4 parts:
- The box (transparent)
- The base (green)
- The ramp (blue)
- The mount (red)
Iām doing it this way so I can print it efficiently and correctly on my home 3D printer.
As it stands in the previously mentioned image, nothing would change compared to the original 1.0 intake box except for the removal of both resonators; however, my idea doesnāt stop there, and the reason Iām putting in this effort is the following:
This is the engine bay of my 1.0. Since it doesnāt have fog lights, the idea is as follows:
Since my Civic didnāt come with fog lights from the factory, Iām planning to connect a pair of pipes to each fog light opening and then merge them under the intake box into a single pipe and attach it to the 3D box Iām making (that way I donāt ruin the original one by cutting a hole in it).
Also, as you can see from my incredible artwork, I plan to somehow adapt an extra inlet (drawn in blue) directly from the front grille to the intake box, making it something that ALL 1.0 owners can adapt to get better sound and better airflow. Iāve marked in the following image where the fog light and grille inlets would go.
Once everything is perfect, Iām going to run a flow simulation on the part in the software to correct any turbulence that might be created with this configuration and fix it.
Iāve planned everything to be Plug & Play, where you only need the original rubber gasket and the screws with the rubber grommets that you can easily remove from your old intake to give your 1.0 more air concentration!
Iāll leave some sample images of the first prototype (spoiler: there are measurements that need readjusting):
Iām just a little mechanical designer, but I plan to do big things with this 1.0 ![]()
Iāll keep updating⦠WIP
