Windshield washer fluid warning
Hi. For a few weeks now, I’ve noticed that the low windshield washer fluid warning isn’t popping up, even though it always used to notify me without any issues. Has this happened to anyone else? Thanks.
Maybe it hasn’t reached a low enough level yet.
Yes, it’s run out of water a couple of times already.
Well, I’d start by checking the level sensor (it’s at the lowest part of the tank) and the float as well, just in case it’s stuck due to limescale or something. Have you been putting tap water in the tank?
Okay, I’ll check it out. I always use tap water; here in Galicia it has very little lime. I’ve never had a problem with any car in that regard. Thanks for the comment.
