Who has tried it? I’ve gone through 5 tanks and I notice more smoothness and lower consumption. In my girlfriend’s car (Fiat Bravo 2011), there was an injector problem where it emitted a lot of white smoke. And it seems to have “fixed” itself by switching to this fuel. But it also suffered two strange breakdowns. The tank gasket apparently “wore out” and leaked gas right when filling the tank. A week later, a hose on the fuel pump also cracked. Coincidence? In the TikTok ad for Repsol, I see similar comments about losing gasoline at the gaskets…
I share the question, let’s see how this fuel is.
I’ve been using regular Repsol diesel for a few months along with an additive, approximately 90ml of DNA Archoil Race Diesel (I think that’s what it’s called… I’m saying this from memory right now)… I’ve slightly reduced consumption and even the engine sound has improved… it sounds quieter… and I’m talking about an Accord 2.2 i-DTEC… I use the gasoline version for the Civic and it’s the same… improved consumption and smoother engine performance… and it ensures you can fill up at another gas station if you need to and there’s no Repsol nearby.
Yo casi siempre tanto gasoil como gasolina me gusta Shell, nunca he tenido problemas
Actualizo de que sigo empleando ese combustible de vez en cuando y es el que me da menor consumo y mayor suavidad . Sin tener que emplear un aditivo. Pero solo lo aconsejaría a vehículos relativamente modernos. Ya que he visto cientos de comentarios sobre las juntas y demás en vehículos con mucha edad
